Hoffman vs Gorton
Polycarp
Member Posts: 135
This summer I'll be adding the sorely needed vents to my one-pipe system.
Using
jpf321's spreadsheet, my system really only needs 2 Gorton #1s (so I'll probably do 3). But while I can get Hoffman 75s at the local supply, I would have to order in Gortons. When you count shipping, the Hoffmans are cheaper .. and the retailer is local if there are any problems.
There seems to be a general preference for Gortons around here. Are they better? Better enough to justify the price and decreased convenience?
Thanks guys!
Using
Thanks guys!
please note...
the sheet does not make recommendations for Hoffman Main vents .. so be sure that you know what you are getting when considering the Hoffmans .. the sheet does have recommendations for Hoffman rad vents IIRC.1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics0 -
Hoffmans...
are a very good valve, but just have less capacity than the Gortons, so are more expensive for larger venting needs. Also, they are not as touchy for use in areas with high ambient temps. Gortons are known to stay closed when ambients are high, even when they should be open.
Both are good choices.The Steam Whisperer (Formerly Boilerpro)
Chicago's Steam Heating Expert
Noisy Radiators are a Cry for Help0 -
Gorton to Hoffman
I saw on the spreadsheet, and on other places on the wall, that 4 G#1's equal 1 G#2 and that 3 Hoffman #75s equal one Gorton #2. If I've understood that right, I should be able to replace G#1s with Hoffmans one-to-one with no problem, I would actually be increasing my capacity some. Since my quantity is based on the slower G#1s, I could also go to Gortons if I ever had the need.
That is, if I am reading those equivalencies right.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
