Why ASME expansion tank
Michael Wagoner_2
Member Posts: 6
I understand that if a commercial boiler comes with a 50lb relief valve the expansion tank needs to be ASME rated. if we put a 30lb relief valve on based on the boiler's btu/h rating, since the system pressure is only going to be around 15lbs, why can't we use a standard expansion tank? does it have to do with the system's btu/h rating as well?
Codes
Depends on local and state codes.There was an error rendering this rich post.
ASME
I believe it is because the boiler is rated for 50# and someone could install a 50# relief valve in the future.0 -
ASME
- 114 Geothermal
