Removing main vents
steam83
Member Posts: 19
trying to peplace my main vents put they are really stuck on there what is the best way to remove these without breaking any thing
more leverage?
have you tried more leverage? like slipping a 4ft piece of 1-1/4" pipe one the end of your wrench .. no jerking movements, just slow steady pressure. others may have more tricks and tips ..1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics0 -
Removing main vent
If they are rusted, try iodine. Don't need much, make the joint wet and give it a half hour or so. It's amazing.
Good luck,
Mike0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
