gravity hot water conversion
Brian Maffioli_2
Member Posts: 13
I have been reading and trying to educate myself about a gravity hot water system conversion I just looked at today. I am pretty confident about the whole process except for the reducing of the near boiler piping.
What constitutes near boiler piping? There is what appears to be a 3 inch supply main that travels at least 10-15 feet from the boiler with some parts hiding inside of a soffit of a finished basement.
How near is near boiler piping?
Thanks in advance.
Thanks in advance.
That piping which is connected TO the boiler...
is NEAR boiler piping.
Rule of thumb, 1/2 of that piping, then one pipe size less, so in your case, 1-1/4" new near boiler piping.
ME0 -
gravity
Hi Mark,
So if I understand this right, if my 3 inch supply main starts at the boiler and continues 10-15 feet away from the boiler, that whole length is considered "near boiler piping?"0 -
Correct
If you wanted to break the pipe back to the first branch, and install a 3" X 1-1/4" bushing, that would be acceptable.
ME0 -
Gravity conversion
Remember, your gravity system is a 2 pipe direct return. When you add a pump the water is going to take the path of least resistance. Reverse the returns or add TRV,s to retain some balance in the system.0
- 114 Geothermal
