always calling low water cut off
dog
Member Posts: 2
i just installed a automatic water feed for a steam boiler with a standard low water cut off with the float inside. It fills fine the first time and then when the boiler is running for a while it starts filling again . I checked it and the switch was closed so I banged on the low water cut off and it stopped filling. so apparently the float was stuck. My question is if I put a new low water cut off in will it solve my problem for good or will it happen again, and if yes after how long. or should I just eliminate the automatic water feed..
see about cleaning it ...
if it's a McDonnell Miller #67 .. you can try to disassemble it and clean it out .. but you may want to have replacement gaskets before you do this .. have a look at my thread over here: http://www.heatinghelp.com/forum-thread/129681/why-we-blowdown-the-LWCO1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics0 -
dog
I took it apart and it is really bad should replace? will solve problem?81083A0
