cast iron baseboard ht maximum 8 inches
robert borders
Member Posts: 48
customer wants to add cast iron baseboard to his new sun room wtih 20 windows max ht of 10 inches. the trim guys want to save at least 2 inches for the trim so ht of basemboard must be 8 inches or less installed.
what brands are out there and what are the hts?
thanks
bob Borders
Bob's Heating
319-795-0822
thanks
bob Borders
Bob's Heating
319-795-0822
here is one...
[url=http://www.governaleindustries.com/govboard.cfm]http://www.governaleindustries.com/govboard.cfm
weil mclain also has it and burnham...0 -
Cast iron
I don't think it is 8" tall though.
I had a similar job last year and couldn't find any cast iron baseboard that was approx. 8" tall.
I think the shortest I could find was 10".0 -
Used stuff
Bauer Bros. salvage in Minneapolis has had this 7'' Weil stuff in recent past. Probably do not have factory tin work for corners, but I saw some once there. They are not necessarily cheap but you can bargain..
Mine here at home measures about 7 1/2 inches off floor installed.
joe0 -
9 7/8" is governale and burnham
the only short stuff I know of is used. Some radiator salvage yards have it but it is not that common. what about some nice ornate radiators? Show the heat instead of hiding it!Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
