wood boiler overheat,dumping heat
mike parnell
Member Posts: 42
Just install a indoor wood bolier, in the event of overheat a L4006B closes and activates a second circulator pulling heat and pumping it into two radiant basement slabs,zones 5,6, question is how to wire the zone 5 or 6 pumps to run without firing the boiler???the L4006B is wired to a sr501 relay at TT, term 6 no and 5 com is now wired to the thermastat for zone 6, but the burner kicks on, any ideas????
bypass relay
Perhaps you might try wiring the circulator(s) directly to the 4006 rather than using the thermostat contacts.
If that is impractical try installing a seperate relay that does not make the boiler circuit.
I assume that 5&6no in the relay for zone 6 is what is making the burner start.
Are both pumps required to operate? P-S?0
