Beckett Genesys Controls, How to adjust pre-post/purge?
cwilliams2000
Member Posts: 140
I thought out of the box this unit would have a std maybe 10 second pre purge, but it looks like it is set to immediate. I know about the contractor module for this, but is there any other way to set this w/o the module? thank you
what part number
what part number is it? such as 7505A-0000
There are several models with different factory settings depending on the application.
To use pre or post purge you must have a delay valve.
The only way to adjust it is with the contractor tool or the clip on display.
hth0 -
no way to change it without module
on the box it lists what the pre/post settings are.
If you don't have the module you got to double check you got the right one.There was an error rendering this rich post.
- 120 Geothermal
- 394 Solar
