Adding additional radiators
Luv'nsteam
Member Posts: 278
Having done heat loss calculations, I have figured out the EDR I need. Using TLAOSH, I have calculated the risers, run-outs, valve sizes, vents, etc, that I need. What I am not sure about, is how the new valve will attach to the new-to-me radiators (have not yet purchased, but am actively looking).
Is there a fitting that screws into the radiator that matches and attaches to the valve? What is this piece called? And how is it sized? Is there anything else I should be asking?
Thank you,
Mike
Thank you,
Mike
SPUD WRENCH
If you purchase WATTS type radiator valves (which are relatively cheap) they come with a union and nipple threaded on 1 side with (2) grooves on the opposite side of eachother on the inside diameter of the nipple. You need a special tool called a SPUD WRENCH to properly tighten this nipple into your radiator. This tool is good for radiator valves 1/2" up to 2" & can be bought at any plumbing supplies, Sears, or Home Depot, etc. Next step would be to apply some pipe sealant dope on the face of each side of the union and tighten.0 -
Watts valve
This link is to Watts home page, searched to "steam radiator valve", in case it does not work.
http://www.watts.com/pro/_productsFull.asp?pid=687&ref=1
Is this the correct valve? If so, the union and nipple you refer to are not shown but, do come with the valve, in your experience?
Thank you,
Mike0 -
yes something comes with valves...
i had wanted only the spuds .. but I had to buy the entire valve I believe.
voila! http://www.pexsupply.com/pex/control/search?SEARCH_STRING=angle+steam+valve1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics0 -
yes...
these radiator valves come with the nipple and union you would need to furnish and install this product.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
