Radiant Heating System
Hydronics_R_Us
Member Posts: 4
Hi all,
Well this will be easy for the seasoned radiant heating technician but quite a challenge for the average. I'm installing a boiler with (2) radiant heating coils and as well as connecting the boiler to a domestic water heater that I want to put on a recirculating pump. Can anyone tell me where I may find some drawings (books/web sites) indicating the required components
Condensing or not?
METhere was an error rendering this rich post.
What?
Hi Mark I just read your post and must admit I'm thouroughly confused. It's a non-condensing boiler.
Les0 -
Modern-Hydronic-Heating
I found this book extremely helpful, and you can get it right here.
http://www.heatinghelp.com/products/Books/5/96/Modern-Hydronic-Heating-Second-Edition-br-by-John-Siegenthaler0 -
The Book
Just wanted to tell you thanks0 -
all high temp then...
http://www.ultra-fin.com/
Any pex-aluminum-pex tubing and conventioanl zone valves.
Don't forget the insulation.
SIggys book is the best.
Siggy's books
Check out Siggy's web site for more for his books/manuals. Real good reading w/easy to follow diagrams. [url=http://www.hydronicpros.com]www.hydronicpros.com0 -
NO PEX
Hi Mike as I stated before it's a non-condensing boiler feeding (2) hydronic coils that are being attached to a heatpump split system. All piping is being done in copper not pex. I think I've figured out most of the particulars just wanted to see if any of the experts have some good ideas to save me time and future problems.
Thanks for the Info.
Les0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
