0-3psi #33020
mikem
Member Posts: 1
in Gas Heating
i just received my 0-3psi #33020 for the steam boiler. Now to put it to work.
I plan to take mthe pressuretropl off the pigtail and the with a T fitting abd a few brass nipples, and elbows, reattach the ptrol to one side of the "tree" abd the 0-3psi gauge to the other side. I will not touch the 0-30psi guage.
I am going to use a black iron union. that way I can get most of it together on the beanch. From the union, the retst will be breass fittings. Should I use the same sealant on both the iron and brass. Teflon and/or rectorseal #5 ?
We stil have the two-pipe, air vent system (1900??) with radiators with two supply valvers and air vents.
Thanks for the help fronm HeatingHelp and Dan Holohans books!
Pressuretrol reattach
If your pressure trol has a mercury bulb, make sure the bulb travel is perpendicular to the pigtail movement. Otherwise it makes no difference. Some gauges are internal trapped and may not need a pigtail trap to protect them. Follow the mfg instructions on the pipe dope container, brass to iron should not be a problem.0
- 120.1K All Categories
- 83.6K THE MAIN WALL
- 2.8K A-C, Heat Pumps & Refrigeration
- 52 Biomass
- 414 Carbon Monoxide Awareness
- 29 Chimneys & Flues
- 1.7K Domestic Hot Water
- 4.6K Gas Heating
- 114 Geothermal
- 151 Indoor-Air Quality
- 2.9K Oil Heating
- 49 Pipe Deterioration
- 735 Plumbing
- 5.2K Radiant Heating
- 355 Solar
- 13.8K Strictly Steam
- 3K Thermostats and Controls
- 50 Water Quality
- 36 Industry Classes
- 69 Job Opportunities
- 14 Recall Announcements
