best tank additive
Rick_41
Rick_41 Member Posts: 67
I have some new tanks and some old ones. I've never cut apart an old tank but I have heard that sludge happens. I used Hercules products that as far as I can tell is nothing more than expensive mineral spirits.
Question: Do you think occasional oil additives are necessary?
Will they create more problems if you add them to an older tank that hasn't been treated in a while (or ever?)
I found this site,..has anyone used this product? Ever see any independent reviews of these products anywhere.
<a href="http://www.fuelright.com/results.html">http://www.fuelright.com/results.html</a>
  • Big Ed_4
    Big Ed_4 Member Posts: 3,362
    edited February 2010
    Better then a additive
    Install the tanks correctly a additive would not be needed and the tank would last last a lot longer too .. Water laying in the bottom breeds sludge .. A bug lives between the laver , eats the oil and poops out sludge .. The bugger can not digest the sulfur and poops out sulfuric acid too ...Great for a steel tank ...right !!! Pitch the tank toward the valve , install legs high enough to place a filter at valve ...Any water will empty in the filter ...Sure sludge would breed at that point ..So once a year change the filter and empty the filter can ... Stay away from top feed tanks too ...Same reason ..
  • Gordo
    Gordo Member Posts: 857
    Fuelright
    Fuelright works.  It breaks up the sludge.
    Good stuff.
