pipe insulation ?
steam83
Member Posts: 19
I am intersted in insulating my steam pipes in my basement i have read
this can be done with regular role type insulation used in walls i was
looking for some good advice on how to get this done what type to use
and the best way to secure to the pipe also i have read some good
articles on using 1" pipe insulation being the best i am on a budget
and already have several roles of insulation sitting in my garage but i
would love some feedback on how to get this done properly and equivelent to the 1" pipe insulation
steam pipe insulation
cut to fit, then use lots of duct tape, stuck to itself, and wound around the pipe..
this is not as "pro" looking as preformed pipe insulation, but will do in a pinch, although will probably need retaping every year.--nbc0 -
tape
would it be better if i used the more expensive reflective silver tape that seals ducts better then plain duct tape0 -
silver tape?
only if the duct tape fails.--nbc0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
