Another floor heating question.
chitowntommy
Member Posts: 5
1. It might be over kill, but I recall a tech friend of mine back in the day using contact grease to assist in heat conduction between an amplifier transister and the heat sink. Is contact grease ever used between the pex tubing and the heat plates?
2. I found a company, Radiantec, that designs and packages under flooring heating, any opinions or thoughts?
Thanks,
Tommy
Thanks,
Tommy
- 86.8K THE MAIN WALL
- 56 Biomass
- 106 Chimneys & Flues
- 5.6K Gas Heating
- 104 Geothermal
- 69 Pipe Deterioration
- 953 Plumbing
- 6.3K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
