R-438A FYI
Eugene Silberstein 3
Member Posts: 1,380
Here is some information regarding another new generation refrigerant that is available for R-22 replacement. R-438A is a blend of R-32, R-125, R-134a, R-600 and R-601a. This refrigerant blend has the same component refrigerants as R-407C, but two pure hydrocarbons, butane (R-600) and isopentane (R-601a) have been added in small quantities. The main benefit of this refrigerant is that it can be used in conjunction with the mineral oils that are presently used in conjunction with R-22. The presence of the hydrocarbons in R-438A facilitates oil return to the compressor by reducing the viscosity, or thickness, of the oil. R-438A is an HFC blend, so its ODP is zero. The operating pressures of R-438A are similar to those of R-22, but its capacity is slightly lower than that of R-22.
You can check out Dupont's website for more information.
Would you say
that this stuff is better, worse or about the same as NU22b for residential systems?0
