laars endurance ebp
allenh
Member Posts: 117
does anyone know of someone who has parts to service this boiler in Camb Mass area?
TT is calling. It makes domestic hot water just fine. Circ pump (external) gets 120 volts but no low side voltage on the other leg. Suspect a honeywell controller.
TIA.
TIA.
laars
You will need to find a company familiar with your local laars parts supplier. You can call them direct, but you may not be able to buy the parts, it depends on who carries their parts in your area. Laars should be able to tell you that as well....
TimJust a guy running some pipes.0
- 114 Geothermal
