Looking for steam trap - please help!
Dan B_2
Member Posts: 6
I have inherited a house with a steam system, and one of the steam trap housings is cracked. I don't need the cover or the internal steam valve itself, just the base housing (the part that looks like older metal) in the pictures attached. Does anyone know where to find these? I suppose I should get an extra while I'm at it! Many thanks, Dan
Looks like an Ideal trap
I'm far from an expert, but that looks like the Ideal Heating Equipment Company traps that I have in my home. I don't think you can get the body/housing any more.
Depending on how badly it's cracked you might want to try using JBWeld. It would at least buy you some time to find a replacement.
http://jbweld.net/index.phpThere was an error rendering this rich post.
Thermostatic Traps
As Brian suggested, you might try the JB Weld first and then think about a new trap. If you can I'd wait until it warms up in the spring before replacing the trap. . Here's some notes I made on traps that might be of help.
- Rod
Thermostatic Radiator Traps
Trap Quality (per Gerry Gill)
1. Mepco (Dunham)
2. Monash Younker
3. Sterling
4. Barnes & Jones
Any of these are good.
Source for complete traps & parts:
State Supply
http://www.statesupply.com/steamTraps.jsp
Rebuild parts for Steam Traps (Thermostatic, F&T)
Barnes & Jones
http://www.barnesandjones.com/
Tunstall
http://www.tunstall-inc.com/tunstallsteam.html0 -
Many thanks
Many thanks!! I will try the sources for different traps you mentioned. I don't mind changing the housing, but I wanted to stay with the same innards, for simplicity's sake. Do all traps take the same internal mechanism? Thanks again! Dan0 -
What is the Number
on that cover?
Where is it cracked?All Steamed Up, Inc.
https://heatinghelp.com/find-a-contractor/detail/all-steamed-up-inc0 -
Trap Parts
No, unfortunately the internal mechanisms are all different. This even varies between models by the same manufacturer. The replacement mechanisms can also be different from the original, even though they are designed to work in a specific make and model. In some cases they are an improvement over the original!
I see Gordo has posted an answer to your question. He's a steam pro and an expert on steam traps so be sure to provide what info you can as he may have some good recommendations.
- Rod0
- 86.3K THE MAIN WALL
- 53 Biomass
- 75 Chimneys & Flues
- 5.4K Gas Heating
- 93 Geothermal
- 150 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 920 Plumbing
- 6.1K Radiant Heating
- 373 Solar
- 15K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
