Tape or plaster over Danfoss remote sensor capillary?
Thor
Member Posts: 11
I find myself the proud owner of about six Danfoss RA2000 valves which were mounted spun around on the supply pipe so they face straight up. I was wondering why they didn't seem to be cycling quite right with the ambient temperature until I noticed the Danfoss installation instructions specifically said to not mount them in this orientation.
I am replacing the thermostats with the remote-sensor version to deal with this (spinning most of the valves to face horizontally isn't an option -- they'd protrude in inconvenient locations) but the silver capillary tube running up the matte white wall next to each radiator is pretty obvious, and not exactly attractive.
Can I channel the plaster and bury the capilary tube, or just hide it under drywall tape/compound, or will this cause a problem? I assume at least there's no reason why I can't paint it, if nothing else will work.
Thanks!
Thor
Thanks!
Thor
Just don't kink the cap tube and you'll be fine.
The cap tube is a transfer medium and not a sensing element. I painted mine into the wall, and it works just fine.
ME0 -
Create a channel
to bury the cap tube in and then put joint compound over it.
bb0
- 87K THE MAIN WALL
- 57 Biomass
- 112 Chimneys & Flues
- 5.7K Gas Heating
- 106 Geothermal
- 70 Pipe Deterioration
- 979 Plumbing
- 6.3K Radiant Heating
- 387 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
