Wall hung CI rad
Patrick_North
Member Posts: 249
Hi all,
Numerous inquiries to different radiator sources have turned up nothing, so I'll put out an APB here.
Looking for a wall hung radiator for one pipe steam. Not getting too picky with edr, but my ideal dimensions are about 2' wide and 3-4' tall. Yes, I need to be able to mount it 'vertically.'
I've tried most (all?) the sources noted here on the Wall (A-1, etc.) and am hoping someone out there has a lead.
Thanks,
Patrick North
Thanks,
Patrick North
Wall hung
Contact me directly and I can see if I can help or send you to someone who can.There was an error rendering this rich post.
wall-hung
I also have like 5 of them, some more ornate than others. I can have them sandblasted prior to sending as well if requested.
TimJust a guy running some pipes.0 -
We might have some in that size
I'll take a look around and see.All Steamed Up, Inc.
Consulting0 -
wall vs. ceiling ..
i'm considering adding a ceiling mounted unit in my basement .. above the dimension of the mains .. my question .. are there any special considerations when mounting on a ceiling, could I just as well use a wall mount? i suppose the most important is the pitch but are there other things I need to consider when mounting on the ceiling.
thanks1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics0 -
ceiling rad
You could strap a standard CI rad to the ceiling as long as the pitch is correct. I see those flat rads on the ceiling above a main all the time, one pipe with vent. Nice way to heat having it above, like the old radiant ceilings.
thanks .. yes i should have mentioned 1-pipe
thanks .. yes i should have mentioned 1-pipe ..
what flat CI rads are you speaking of? like the ones in the above pics?
thx.1-pipe Homeowner - Queens, NYC
exactly
Just like those. I found a website that carries LH/RH nipples but I just piped the bottoms together with a full size nipple and a union when I needed 2 combined and had no issues....
thx Timco
thx Timco -- i messaged you directly.1-pipe Homeowner - Queens, NYC
- 62 Biomass
