Water baseboards generating clicking noise
Dezso3
Member Posts: 11
My room is heated with a hot water baseboard heating system. As soon as the system was installed, it was making clicking noises. I figured out a way to attach the pipes to the baseboards, and the clicking noise went away temporarily. Just
recently, I accidentally knocked a textbook from my desk right on top
of the baseboards, and after that, when the heat came on, they started
clicking like mad, all over again. What I have noticed is that the
pipes and the metal baseboard covers only make the clicking noise if
the covers are attached to the support brackets; if I remove them, the
clicking ceases. I believe this is because when the covers are on, they
pull the support brackets tightly together, which increases tension
between the support brackets and the pipes. When the pipes heat up and
begin to expand, they do not have enough room to do so, and it results
in a clicking noise. However, I am not positive that this is what is
creating the noise. It's extremely annoying because I
wake up early in the morning whenever the heat comes on and cannot sleep. What the heck can be done about this?
Reducing the sound
Some manufacturers (Slant-Fin) have several plastic (spacers per piece) attached to the fins, that act as a spacer between the cover. If the fin tube is not setting on the brackets correctly, and is pushed forward to touch the cover, it will make noise. The piping to the baseboard may also be contributing to the issue, if not plumb and square to the correct centerline of the BB.0
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 971 Plumbing
- 6.3K Radiant Heating
- 386 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
