Thermostatic zone valve vs. Circulator
Kungur
Member Posts: 49
Is it feasible to use a thermostatic zone valve to "zone" a section of the house, the bedroom, instead of using a circulator for that zone?
Never Heard of a Thermostatic
Zone valve. If something is thermostatic does that not mean it has to mix water temp? ie, Mixing Valve? Which in turn means you need a pump for the system side.There was an error rendering this rich post.
I am not suggesting that I will not need a circulator. What I am wondering is instead of multiple circulators can I accomplish the same thing with a zone valve. I.E. I would like to control the master bedroom seperately. Could I use a zone valve vs. a circulator .0 -
Sure
As long as you have a system pumpThere was an error rendering this rich post.
Thanks!!0
- 86.8K THE MAIN WALL
- 56 Biomass
- 106 Chimneys & Flues
- 5.6K Gas Heating
- 104 Geothermal
- 69 Pipe Deterioration
- 953 Plumbing
- 6.3K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
