WHAT TO BUY??
Irv
Member Posts: 95
GUYS,
THE PA404A I HAVE IS INACCURATE.U SET THE SPRING TO LIGHT AND THEMICROSWITCH DOESN'T WORK
I AM READING THAT THE CURRENT HONEYWELL VAPORSTAT ARE NOT MUCH BETTER. EVERYONE WOULD LOVE TO SEE A MERCURY ONE.
THE QUESTION OF THE DAY BECOMES, "WHAT TO BUY?"
THANKS............
THANKS............
you can ..
two suggestions both thanks to Mr. Gill ..
1) Read the thread in the "controls" forum called why vaporstats suck. And notice where he talks about adjusting the "jeweler" screw. My vaporstat, brand new worked like a charm .. then I made the mistake of adjusting the normal adjustment screws .. then it was a train wreck .. when I finally got around to playing with the jeweler screw it is very much functional and back to accurate (or nearly accurate) operation.
2) You can build a highly accurate pressure controller such as Mr. Gill did in his pictures located here ... which implements a HydroLevel Safgard Tank Pump Control just like this one .. http://www.hydrolevel.com/new/index.php?option=com_content&task=view&id=23&Itemid=37 .. he is using 2 Safgards in his picture to control HIGH/LOW fire, if you have only one fire level, you only need 1 piece. It works from the principal that 1oz of pressure raises a water column 1.75" .. he has the Pump Level controls inside the black pipe and the gauge glass simply for visual inspection.
good luck1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
