Steam Radiator Vents
mike jones_2
Member Posts: 89
Our gorton vents have a float that closes them when they fill with water from wet steam.
Does anyone know a less impressive vent that does not have this safety feature so we can try a different vent temporally while we solve our wet steam problem?
Varivalve
From heat-Timer
They'll most likely spit, however.All Steamed Up, Inc.
https://heatinghelp.com/find-a-contractor/detail/all-steamed-up-inc0 -
wet rad vents
thanks for the vari valve rec.
at this point spitting would be fine if the radi doesnt stop working!
do u know if it has a design with vacuum breaker?.
we really appreciate the tip!0
