Primary Secondary Pumping
CCD
CCD Member Posts: 5
Hi All,
Please tell me with primary secondary pumping, what is a safe distance to space tee's away from the tee's that connect the two circuits? If the tee's from the primary to the secondary circuit need to be a minimum of 12" apart from each other to function correctly, how close to either of these tee's in the secondary loop be?
The objective is to pipe primary secondary and clean up the near boiler piping. Just a guess but 20"? 'P and S Pumping made Easy' does not mention this dimension.
Thanks in advance for your time and talent.
