pressure relief valve?
Hollis
Member Posts: 105
Have you ever seen them fail to the fact they don't open? In looking at them it seems unlikely but there is also at lot at stake if one didn't. Do you think its worthwhile to come off the port with a "T" and put two on?
PRV
Yes, I've seen them fail in the closed position, at least in hot water systems where the pressure on the gauge exceeds the opening pressure stated on the relief valve.
I don't see any reason not to install redundant relief valves.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
