English radiators
David_50
Member Posts: 6
I've looked at a couple of British web sites with scads of stylish steams stuff. I did the conversion from watts to BTU to square feet- should work. Needs some metric adapters. But can you get it in the US?
David
David
Hey- it's not a dumb idea
My wife is Russian. Everything there is two pipe steam with tiny radiators (in new installations).
I guess it's tubes in the floor or nothing.0 -
My advice
to you is to stick with radiators you can buy in this country. As beautiful as they look, there are often problems. Late shipments, back-ordered items that never get filled, dropped orders, wrong dimensions, damaged in transit..........
Just my 2¢8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Dimensions
The rads you are looking at will likely have running threads rather than tapered. This is definitely something to be considered.There was an error rendering this rich post.
Super Dope
I've been recommending this thread sealant for years:
http://www.argco.com/store/Main.aspx?p=itemdetail&item=1010085
It's anaerobic and will seal where other sealants fail.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Thread Sealant
Does this stuff work with steam?
Do they sell it in slightly smaller quantities!?
What's the shelf life?All Steamed Up, Inc.
https://heatinghelp.com/find-a-contractor/detail/all-steamed-up-inc0 -
radiators
Check out burnham boilers company
they have some fancy radiators and regular ones.
[url=http://www.burnham.com]www.burnham.com0 -
Thank you gentlemen
I think I'll walk Burnham literature down to Bayonne Plumbing and steer my wife to the Manhattan design place.
I'll check back for a few days. I'm having fun with my little steam system.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
