Aquastat replacement
Scott13
Member Posts: 8
I have a 36 year old boiler with an aquastat that does nothing. I'd like to replace it with a new one, as I can not get the temperature in my boiler above 150 degrees, which does not quite heat my house up sufficiently when it gets down around 0 degrees fahrenheit. The problem I am having is that the current aquastat is a Honeywell T5001A and it looks as though this product is long gone. Can I replace this thing with pretty much any aquastat, or do I need a specific model?
Thanks for any help in advance.
Scott
Scott
There Are
24 T5001A that come up when I cross ref. Do you have the last 4 numbers.There was an error rendering this rich post.
Attached is a picture with what is stamped on the side.
First line: T5001A
Second Line: V5155A1730-3
Last Line: CU30 -
Uhhh. That's not just an aquastat...
That's a modulating gas valve. And they used them for a reason. My suggestion is that unless you are extremely proficient, you would be best to seek good professional help.
If the heat exchanger is crudded up, and you start sending full capacity BTUH into the heat exchanger, you could end up in the back pages of a news paper (read obituaries).
Serious stuff here.
ME0 -
There are no
replacements listed period by honeywell for this vlv. Like Mark said, Seek professional help.There was an error rendering this rich post.
