Adjusting Cut-In
Pat_M
Pat_M Member Posts: 16
Couple of questions:
1 - Can I adjust the cut-in and cut-out while the boiler is hot/running? (Can I open the pressuretrol to get at the cut-out while the boiler is hot/running?)
2 - I can't seem to move the cut-in lever. Should I simply be able to push it down? Couldn't do it with my finger. Couldn't do it with a flathead screwdriver. Don't want to risk breaking it. Tips/thoughts? (It's only a couple years old -- not rusted or anything.)
Thanks!
