Main Air Vents
HenryT
Member Posts: 128
I am planning to vent my mains and have 1 question before making the purchase on the vents.
I have a finished basement with main hidden above dropped ceilings. I have located the end of main and want to vent it with a bigger vent. However, due to height clearance area I may not be able to add a Gorton #2. I was looking a Pex Supply and saw a Hoffman 75.
Are these comparable to Gorton? I know the overwhelming choic would be Gorton due to its venting capacity, but am I sacrificing a lot with a Hoffman 75?
What if I use the menorah approach and attached 2-3 of these Hoffmans?
Any inputs would be much apprecaited and thanks in advance.
Wishing Dan and everyone of you wall addicts a very prosperous new year!
about 1/2
Hoffman 75 has about 50% the venting power of the G#2. FYI, a G#1 has roughly 25%-30% of the G#2.
jpf1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics0 -
Thanks a lot
Thanks!
I think ill just do a menorah setting up with 2 hoffman and a 2 G#1.
Pex supply does not have exact sizing on hoffman. Does anyone know the height for it?0 -
hoffman size
Here is a link to the hoffman data sheet for the #75:
http://www.hoffmanspecialty.com/pdf/hs900/HS900-steamall.pdf
I do not know the height for the G#1 .. perhaps someone else can provide that data.
I think your post implies that you will install 2pcs of Hoffman #75 and 2pcs of G#1, is this correct?
Thanks again
Yes, i plan to put 4 vents becuase you can never overvent.
why do you see a downside in this set up?0 -
Technically, you can overvent
You can "overvent" if you add too many vents for the the capacity of a pipe. For example, two Gorton #2's on a 1/2" menorah overwhelm the venting capacity of the pipe itself. It's not going to hurt anything; it's just a waste of money.
Personally I think any combination of Hoffmans or Gortons will work just fine.
A Gorton #1 is a little over 3" tall.0 -
no downside...
i don't see a downside .. the wording of your post was a bit confusing "a 2 G#1" .. i just wanted to be sure you were meaning "2pcs of G#1".1-pipe Homeowner - Queens, NYC
Main air vents
How much actual room do you have to install the vent?0 -
hey Mel.
Hi Mel. i know i still owe you update on downfire. I have enlisted another pro off this forum and will let you know how the appt went.
back to the question: Well, the on the end of main tapping, i need to add elbows and nipples & tees to make the menorah, which will cut into my overall clearance. Even with that set up, i have about 3"-4". So settign up a menorah with multiple G # 1 or Hoffmans is probably the best solution for me in order for me to get the same venting as a G#2.
I have another question regarding main venting i am asking for a buddy.He just purchased a home with 1 pipe steam heating. His end of main runs from basement into the first floor strangely enough. on this pipe, there is a hoffman vent there (1/8 NPT) fitting. and it HISSES like NO TOMORROW when there is a call for heat. it is LOUD. i am planning on replacing this for him but the 1/8 tapping can be an issue,. Can i put a nipple that increases that tapping to 1/4 or 1/2 NPT and add a Gorton on that line.
I have no clue why the end of main is there. its sitting in the corner and runs about 5' into the first floor. Is this the Main or is it a riser meant for a removed radiator?0 -
venting capacity of 1/8th hole
you can install fittings to properly install a reasonable vent in that 1/8th tap .. but keep in mind that it will only support the same capacity of 1pc G#2 or less .. anything more that 1pc G#2 is wasted money because you can't vent any faster through that size opening .. this is equivalent to Mr. Nadle's comment about overventing ..
FYI .. 1/2" NPT has capacity to vent roughly 2pcs G#2 + 1pc G#1 anything more on 1/2" is wasted money.1-pipe Homeowner - Queens, NYC
JPF321
Thanks again.
I will buy bushing and coupling to "upsize" that hole. Do you think it will still hiss being that we are sort of make shifting a small hole to fit a big vent.0 -
in theory...
the hissing is a function of an overworked vent (to small an opening on vent) .. with a larger vent you should have less/no hiss...but then there's also this: http://www.heatinghelp.com/forum-thread/128591/Leaking-Gorton-21-pipe Homeowner - Queens, NYC
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 975 Plumbing
- 6.3K Radiant Heating
- 386 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
