radiant no flow
jim_160
Member Posts: 24
i've got a radiant system with four seperate zoned manifolds. each manifold has a 008, with a honeywell thermostatic manual mixing valve. it has been in operation for 8-10 yrs. the piping off the boiler is a supply out to manifolds and a seperate return back from the manifolds to boiler. there is a hot by-pass from supply to return @ boiler to mantain 135' at return. the bypass is thermostatic with a mixing valve and 007. ive purge air from system, but i can't get flow through manifolds out to system and back to boiler. i can send pictures if you need
jim
jim
Send pictures
We need pics!Class 'A' Gas Fitter - Certified Hydronic Systems Designer - Journeyman Plumber0
- 120.2K All Categories
- 83.6K THE MAIN WALL
- 2.8K A-C, Heat Pumps & Refrigeration
- 52 Biomass
- 414 Carbon Monoxide Awareness
- 30 Chimneys & Flues
- 1.7K Domestic Hot Water
- 4.6K Gas Heating
- 114 Geothermal
- 152 Indoor-Air Quality
- 2.9K Oil Heating
- 49 Pipe Deterioration
- 736 Plumbing
- 5.2K Radiant Heating
- 357 Solar
- 13.8K Strictly Steam
- 3K Thermostats and Controls
- 50 Water Quality
- 36 Industry Classes
- 70 Job Opportunities
- 14 Recall Announcements
