lwoc
GTD
GTD Member Posts: 33
Hi i have weil McLain 368st oilfired boiler with a m/m 67 lwco  on it the inside of the housing it is pitted, Is is wise to take apart and scrape the inside of it. Also   on the chamber door what do they use for the gasket to put the door back on the boiler, the one that comes with the chamber kit ,is garbage,if stove rope is good what size to use. thanks tom
