failed taco pump
Tom1
Member Posts: 2
If I have more than one taco-007 pump in my system and one fails
will water pass through the failed pump, or will gravity feed pass
through a idle pump.
only if you have opened the flow check
If you have spring flow checks than no. The gravity flow would not be very much, if any, if on radiant heating due to the small pipes and the long runs. If you have baseboard it will be a little better but still not enough for heat.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
