Overheated rooms
Dezso3
Member Posts: 11
My house has a steam heating system, and ever since I have lived here,
one of the rooms in the house has always been overheating. While the
thermostat in the dining room is set to 70 degrees F, the temperature
in the second floor room I mentioned is about 80 degrees F, and can even go up to 90 F at times. The
overheating is exacerbated when it gets really cold outside, especially
below 20 degrees F. The radiator in the room is 24" tall, 20" long, and
4" wide, has a Gorton No. C vapor equalizing valve. The room itself
measures about 10 x 12 ft. It seems that the reason that the room is
overheating is because the bottom floor is so drafty that it takes
longer to heat up than the second floor, resulting in uneven heating.
However, I am not sure :/
That's a fast vent
Try a Gorton 5 or 6, or an adjustable vent instead.0 -
try an adjustable vent....
you can try putting on an adjustable vent .. like a Hoffman 1-A (available here)
you may even want a TRV (available here) .. but only if the adjustable vent doesn't work ..1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics0
- 84.3K THE MAIN WALL
- 53 Biomass
- 417 Carbon Monoxide Awareness
- 44 Chimneys & Flues
- 1.8K Domestic Hot Water
- 4.8K Gas Heating
- 120 Geothermal
- 156 Indoor-Air Quality
- 3.1K Oil Heating
- 58 Pipe Deterioration
- 799 Plumbing
- 5.5K Radiant Heating
- 371 Solar
- 14.1K Strictly Steam
- 3.1K Thermostats and Controls
- 39 Industry Classes
- 80 Job Opportunities
- 22 Recall Announcements
