steam coils - F&T trap or thermostatic radiator trap?
Typically on steam coils is it best to use a F&T trap or a thermostatic radiator trap. Each coil is about 10,000 BTU's each.
    Steamhead Member Posts: 18,187
    I'd use an F&T
    since it will drain condensate more quickly. If the coil sees outside air, I'd include a vacuum breaker so water won't be held up in the coil and possibly freeze.
    Consulting
