vapor question
Timco
Member Posts: 3,040
I have a customer with a vapor system, piped in a dead give-away method including the return trap. However, the return trap was long ago abandoned, who knows why. Should this trap be replaced or repaired, and reintroduced to the system? She does get a bouncing water line, but not really any no-heat situations due to low water. Second, this boiler has a standard pressuretrol. Never builds pressure, and seems to not be able to either. What would have originally run this boiler so it does not just fire forever during a heat call? Last, if the boiler is replaced, is the use of a vaporstat the only needed part to keep it vapor or should it just be run as a normal 2-pipe setup? All standard valves & traps, but typical return trap between 2 check valves. Building does heat now, but I want to make it better, and learn while I am at it.
Tim
Tim
The Return Trap can be rebuilt
but I'd switch to the Vaporstat first. If they start shutting radiators down the pressure will build to the point at which it will overcome the "B" dimension, unless you have a Vaporstat or a working Return Trap.
Take some pics!All Steamed Up, Inc.
Consulting0 -
pics coming
But until then, it is piped exactly as shown here. I am glad to scan the entire section discussing vapor if anyone is interested.Just a guy running some pipes.0 -
pics coming
sorry...double click...Just a guy running some pipes.0 -
posting attachments ...
i think you can only post .JPG images or .PDF docs .. if you upload them somewhere else and post a link, i'm sure people will look at them.
jpf1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics0 -
jpeg
My scan is a jpeg but I just get a blank white screen after browsing and attaching. Sheeeesh!!Just a guy running some pipes.0 -
JPG or JPEG? It may matter here...
.1-pipe Homeowner - Queens, NYC
scan
I think it just scanned in too big. It was like 7000 x 4000 or something like that.Just a guy running some pipes.0
- 84.3K THE MAIN WALL
- 2.9K A-C, Heat Pumps & Refrigeration
- 53 Biomass
- 417 Carbon Monoxide Awareness
- 44 Chimneys & Flues
- 1.8K Domestic Hot Water
- 4.8K Gas Heating
- 120 Geothermal
- 156 Indoor-Air Quality
- 3K Oil Heating
- 57 Pipe Deterioration
- 794 Plumbing
- 5.4K Radiant Heating
- 369 Solar
- 14.1K Strictly Steam
- 3.1K Thermostats and Controls
- 53 Water Quality
- 39 Industry Classes
- 80 Job Opportunities
- 22 Recall Announcements
