Do water baseboard heat systems ever share hot water with the tap hot water?
davidd31415
Member Posts: 1
Hi,
I live in an older home and from what I can tell it looks like the hot water from the baseboard heating system is shared with the hot water that comes out of the tap.
If the heat has been on for a considerable period of time sometimes the hot water runs out quickly. This alone makes me think that the hot water that comes out of the tap must also be the same water which is circulating in the pipes but I'd like to know for certain.
Thanks!
David
Thanks!
David
I hope not
If you turn on the hot water tap without cold water you would get instantly burnt. What type of boiler do you have? Does the boiler have a hot water coil in it? Take a few pics and post."The bitter taste of a poor installation remains much longer than the sweet taste of the lowest price."0
- 120.2K All Categories
- 83.6K THE MAIN WALL
- 2.8K A-C, Heat Pumps & Refrigeration
- 52 Biomass
- 414 Carbon Monoxide Awareness
- 30 Chimneys & Flues
- 1.7K Domestic Hot Water
- 4.6K Gas Heating
- 114 Geothermal
- 152 Indoor-Air Quality
- 2.9K Oil Heating
- 49 Pipe Deterioration
- 736 Plumbing
- 5.2K Radiant Heating
- 357 Solar
- 13.8K Strictly Steam
- 3K Thermostats and Controls
- 50 Water Quality
- 36 Industry Classes
- 70 Job Opportunities
- 14 Recall Announcements
