Which is better heat transfer?
Ricwall
Member Posts: 2
Which transfers more heat inside a water tube boiler furnace. The flame, or the combustion gases generated by the flame?
Assume the flame is not impinging any water tube.
Would appreciate a short explanation why. Thank you
It depends...
It depends on the amount of radiant and convective heat transfer components in the flue gas stream. Radiant surface accepts the radiant heat from the flame; whereas convective heat transfer takes place in areas of the furnace that are shielded from the radiant energy of the flame. A flue gas economizer for example is 100% convective and sees no radiant heat. For a more detailed explanation, see the B&W steam book. The design of the boiler takes into consideration the flame characteristics-whether it is oil, gas, or solid fuel, and optimizes the ratio of heat transfer characteristics to produce a cost effective boiler assembly with the required efficiency. Hope this helps...0
