Burner tubes are rolling
BIG DOG_3
Member Posts: 2
Installed a Dunkirk 4 section gas/water boiler 6 weeks ago. Gotthe no heat call yesterday and discovered the roll-out switch was burnt. replaced it with the extra switch that comes with the unit. After re-firing unit was stunned to watch the burner tube actually rolling and rocking in the tray. tried to clamp down frt panls on tubes to hold in place and appeared to work great. stayed for 1/2 hour and unit fired fine. Got a call this morning, no heat. rollout switch burnt up again. any help?
I would be on the Horn...
to Dunkirk ASAP... somethink is a miss here. kpc0
