WHAT IS THIS VALVE FOR
john_181
Member Posts: 93
Hello guys, Can anyone tell me what this valve is for (or was for). It is installed on an old 80+ year old hot water boiler system. It is on the return side of the boiler. I believe the system use to be a gravity system but not sure. This old valve says DELTA 125 on it. It has a plunger that works up and down. The plunger was activated by a unique device that was installed on top of the valve. It had a tank or canister that when heated by an electric element attached to it - heated up a liquid in it and pressed the valve down. I have no idea what it was for or anything. I attached a picture to show it. sorry for all the arrows - i used the pic for something else. The valve is under the yellow arrow on the left side of the picture.
can we guess?
Sounds like to me maybe it was the first go at a zone valve.What control the electric element?0 -
what controlled it
it was controlled by the thermostat0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
