shifting radiator position?
bethb
bethb Member Posts: 1
I am moving into a new condo and one issue is the direction of a radiator in the living room. I don't want to replace the radiator, just spin it around so that it runs the length of the room north-south, instead of the width of the room east-west. Is that possible? Is it expensive for a plumber to do? I'm afraid my furniture won't fit in the room the way the radiator is currently positioned!
Thanks,
B
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,875
    It depends....
    If it is steam, it might not be easy or feasible.
    If it is hot water, it has a 50/50 chance of being moved.
    If the space below you is an occupied unit, you will need their permission to do the work.
    If the space below you is a concrete floor, it could be VERY expensive.
    Best see the advice of a practiced professional.
    ME
