source for over-radiator water "buckets"
jpf321
Member Posts: 1,568
im not sure what they're called .. the things that hang on radiator that you fill with water to help room humidity.. anyone know where to find them or if they have a real name? are there any that are better than others? plastic? metal? thanks!
1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics
Radiator Humidifiers
I looked into this last winter. There isn't much of a choice out there. Some are made of plastic which since it doesn't conduct heat, seem almost useless. Some are ceramic, very decor and very expensive. One that was interesting and reasonably priced I kept the URL and here it is http://kilian.stores.yahoo.net/radhum.html We ended up using small aluminum foil pans which my wife found somewhere. They may be bread pans or dripping pans as they are similar to the ones we use on our barbecue .
- Rod0 -
couldn't find @ Kilian however ...
Thanks Rod
Kilian didn't seem to have anything on their site .. at least not at the link you sent ..
I did find a NY Times article with several options .. http://www.nytimes.com/2007/12/27/garden/27room.html
The plastic ones "Snow Joe" are available here: http://www.homeandbeyond.com/prod-8554200209.html
This one is pretty stylish .. I don't think it "hangs" though .. http://www.cookware.com/asp/show_detail.asp?sku=RY1696&refid=GANk232270
I'm wondering if my local coppersmith would fabricate a couple .. and at what cost? I'll keep y'all posted.1-pipe Homeowner - Queens, NYC
my NEW system pics | my OLD system pics0 -
Radiator Humidifier
Sorry about that- Not sure what is wrong with the link as it worked okay for me though when I used it on here after I'd logged off, it didn't work. I think this one will work [url=http://kilian.stores.yahoo.net/radhum.html]http://kilian.stores.yahoo.net/radhum.html
Here's the pictures of the unit. They are $14.99 ea. and $54.00 for 4 each
- Rod0 -
My grandparents had something like this...
.. but in the part that went between the radiator columns, there was a felt-like element inserted that extended about 1/2 inch above the metal there, so as to be directly heated by the radiator itself. The end where you put the water in was round, like a large can for stewed tomatoes or something, so it held more water than the one you show.0 -
I have a customer with one in her radiator.
Her husband had his waiting room in the front room and he had one in that radiator. It still has the felt in the area between the radiator. Hers still has the original label on it. Next time I am there I will see if I can get a photo of it.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
