Gas Fired Boiler Comparisons
Curios
Member Posts: 1
I need to replace a 40 year old low efficiency gas fired boiler. Is there any particular model to stay away from or people preferred?
Right now I am looking at
-Prestige from Triangle Tube
-Conservator 90 series from Lenox
-Ultra PHD from Weil-McLain
-Slant fin
Are these all made the same or is there a difference??
-Slant fin
I know nothing about the others, but it is the W-M Ultra-2 that has a PHD controller in it.
I do not believe you can get the Ultra-2 series anymore, because they have been replaced by the Ultra-3 series that has a Ucontrol board instead. It is more flexible than the PHD one (you can have three thermostat connections, each at a different priority, and each can have a different output temperature).
They may also have the Ultra-3-UE series, but I do not know what the difference is.0 -
No one makes a bad boiler
I do not believe there is a "best" or "worst" boiler.
Choose the installer first. Let them decide what would be best for your particular installation.
The installation is key.
I have two lines that I prefer and always quote. I have factory training from both, I have parts on hand for both. I have a very good relationship with the local wholesalers of these brands and the local reps.
Make sure they do a heat load calculation.0 -
Now that is
The right answer Mr. Jonas . The second part to that equation is finding that installer with the same frame of mind, and credentials as yourself. In the cconsumers area...Find a Pro Box.
Gordy0
- 86.9K THE MAIN WALL
- 57 Biomass
- 110 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 981 Plumbing
- 6.3K Radiant Heating
- 387 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
