Water heater: Indirect versus direct
I have a Bradford White gas hot water heater, while the heat is with a WM SGO-4 steam boiler.
If an indirect water heater was connected to this boiler (85% efficiency), would it be less costly to heat the water.  Or is that fact that this is not a condensing boiler, make it a wash.
What will it take to get real efficiency numbers for hot water heaters?
Thanks,
Steve
Steve from Denver, CO
