Help w/ an older HW convector - flush? / replace? / options?
I've just switched from an older (1940) oil heat HW system to a gas HW system.
We split out the 2nd floor to a new zone, and kept the old pipes / convectors.
The problem:
The 2nd floor, though it is on a different circulator, doesn't seem to get very hot.  However, the temperature of the pipes feeding the convectors, both input and output are _very_ warm.
Is it possible I need to 'flush' one of these convectors? - does crud build up in them, and that could be why the transfer of heat isn't happening?
What are my options - can I replace the small - 4" x length little radiator inside?
If it turns out that the 2nd floor just doesn't have enough radiation (from when they built the house) is there a place I can calculate what the heating requirements would be?
Thanks,
-Rick
  • Robert_25
    Robert_25 Member Posts: 554
    Dust
    Have you cleaned the convectors to make sure the fins inside are free of dust?  You would be suprised how much a little dust inside the convectors can reduce the heat output.
    How are the convectors piped now?  Were they on a single monoflow loop before?
  • Alan Welch
    Alan Welch Member Posts: 270
    air
    Have you bled the convectors? you would be surprised how much a little air will reduce the output.
Welcome
It looks like you're new here. Sign in or register to get started.
