installed viessman 10 boiler with nx becket
renfree
Member Posts: 1
in Oil Heating
burner won't fire up . bled lines no air can't figure out any suggestions zones are calling burner kicks on for 8-10 sec then shuts down no ignition.
I'm no burner man but
I am a plumber/pipefitter and sub out the burner work, but when the fuel source is in question you can prove it by supplying the boiler with a small can and a short tube.0 -
Need...
Need more info. Oil coming out of nozzle line? Air setting? (to far open) Ignitor working? Proper nozzle in and tight? Electrodes set properly? etc.0 -
How Old
How old is this Vitorond 100 ? A couple of years ago now they had some big issues with the NX burner. Does your boiler have the stainless steel insert for the combustion chamber ? You could always contact RW Beckett.0 -
close the air 90%
just till it lights. then adjust with instrumentsThere was an error rendering this rich post.
riello
why did u get the NX???? runs much better with riello0
- 120 Geothermal
- 169 Indoor-Air Quality
