Never going back to delta P valves
Josh_10
Member Posts: 786
Well, I have 5 systems now installed with either Grundfos Alpha's or Wilo Stratos. I have to say, the convience of not having to install and balance a delta P valve is more than worth it. We're actually saving money when we install the Apha's. When you factor in the extra labor for the bypass valve, the extra ball valve, fittings, and a means of measuring the flow, you come out cash positive. Super easy to install too.
