New Air Vents in Old Radiators
jjjessek
Member Posts: 4
I have some old radiators in my house, and in the course of removing a bathroom I had to drain the system. The problem is that they do not have air vents that I need to refill the system. They do have plugs, but these have resisted all attempts at removal by impact drivers or by screw excractors.
My question is whether I can tap out threads in a new place on the radiator to screw new air vents into it. The plugs are in the end of the radiator on the left side, and I am thinking of tapping out threads on the same end on the right side.
Is this safe? The cast iron where the plugs are is a little thicker than the metal in other places on the radiators and I am worried that the pressure in the system might cause problems if the hole that I would drill in it compramised it.
Any thoughts?
Any thoughts?
- 120 Geothermal
- 169 Indoor-Air Quality
