Two Element Baseboard Enclosure
Does anyone know of a source for 2element base board enclosures? According to the Slant/Fin heat loss program I need 33 ft of element for a kitchen. The way it is I can only put in about 20 ft. Kick space heaters aren't an option. I was surfing a couple days ago and saw a picture of a enclosure with 2 elements, the picture was just there and the article was about someting else. I thought it was a Taco site but, of course I can't find it. I checked out all the Baseboard Mfgs web sites and can't find any with 2 elements. A lot mfgs have the option of supply/return in the same enclosure but not really designed for 2 elements. Can anyone help. I'd really appreciate it. Thanks!
2 tier,,,,
How about this? [url=http://www.slantfin.com/documents/114.pdf]http://www.slantfin.com/documents/114.pdf
ALWAYS let your supply enter the top-run, then spiral-down(in series) to the lower portion, and your output will be even. :-)0 -
try this ...
[url=http://www.smithsenvironmental.com/heatingedge-brochure.pdf]http://www.smithsenvironmental.com/heatingedge-brochure.pdf
Stuff works but it is $$$$.0 -
Try this
The high output baseboard made by Argo will accept a double element. The output is about 1000 Btu's per ft. It is also sold under the WeilMclain name.There was an error rendering this rich post.
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
