Steam - what is this widget ?
PHM
Member Posts: 15
What is this steam-system widget ?
It was connected to dry cleaner pressing equipment. One on each machine I guess as there are a bunch of them now laying around on the floor with all the loose piping.
It's cast aluminum and has cast-in fins around it..
The plugged end and the side opening are 3/8" female pipe tappings.
The other end connection is 3/4" female pipe.
It says: Bishop Evanston Ill. on it.
Here's a pic - <a href="http://tinyurl.com/yhqbrl5">http://tinyurl.com/yhqbrl5</a>
Any idea what purpose it may serve ? No one at the facility seems to be able to remember whether it was in the steam supply or the condensate outlet of each machine.
And, if it was on the outlet - before or after the trap.
It's just an empty hollow casting. It's the fins which puzzle most - why would anything be Trying to lose heat from steam? Unless it was to make condensate water faster for some reason.
Any ideas?
PHM
Any ideas?
PHM
no replies?
Gees, Mikey, I can't believe none of the Wallies has answered this yet! What's wrong with these boys!
Loonie0 -
Just a guess…
Could it be a handle of some kind? The fins would keep it cooler.There was an error rendering this rich post.
Maybe...
Could it be a water hammer suppressor, the fins being reinforcements to the structure?0 -
Widget?
Are you sure it was connected to a steam line?
Most of the machinery (that I've seen, anyway) in a cleaners has steam and/or compressed air connected to it.
It may be a compressed air accumulator, they compensate for undersized air lines.
Glad to see you here, Mikey. Stay here long enough and you'll never go back to The Dark Side (scorched air).0 -
if its a Bishop..
Only the Pope will know what its is.. Perhaps from the chess set?0 -
I'll take a crack at it ...
How about a condensate cooler. It would collect the condensate and inject cold water to cool it before it is discharged to the sewer. (Hey, I gave it a shot.)
A phone call to the Bishop Freeman Co. @ 847-328-5200 would probably put an end to the speculation.
Wayne0
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 974 Plumbing
- 6.3K Radiant Heating
- 386 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
