First steam in years.(jalcoplumb)
jalcoplumb_2
Member Posts: 172
<span style="font-size:12pt">It has been a good few years since my last steam install. I had to re-pipe the old 2” single take-off header with a new 3” double take-off header. I bumped the equalizer line up to 2”. Due to a lack of combustion air in the basement I added a Field Controls CAS-4 “Fan in a Can”. To my amazement I found that the old boiler was sized properly (even though the near boiler piping was a mess.) I installed a new Burnham IN-7 electronic ignition w/vent damper. The old boiler was a Burnham 407. That poor thing had seen a couple of flooded basements and a lot of make-up water due to a leak in the return. It was 19yrs old and there were three sections rotted thru at the water line. The steam leaking was causing roll-out and melted the ignition control. Thank God it melted and failed. The old boiler was rusted and the roll-out switch screws had corroded away, it was on the bottom of the unit nowhere near the flames. </span>
<span style="font-size:12pt">Jalcoplumb</span>
Nice looking job
and that's one way to handle combustion air. Another would be to use a wet-base boiler with a Carlin EZ-Gas power burner, which can be equipped with an air boot. Not sure if the Midco or HeatWise power gas burners have this capability.All Steamed Up, Inc.
Consulting0
- 114 Geothermal
